It’s been happening for couple a days. I haven’t figured it out if it’s a specific spot yet. I can cut squares in the picture. I can cut almost every shape or little detail in the red box (the first 400x400mm area). I haven’t used area above that much since I don’t needed it yet. But here in the second picture where I try to cut some stuff at centered around 400-410 in Y 90-180 in X I get ALARM:2 G-code motion target exceeds machine travel. Yet I can cut square at 780-750 in Y 370-390 in X
TLDR: I can cut anything in the first picture. I get “ALARM:2 G-code motion target exceeds machine travel” when I try to run the second picture.
I use Ortur LM3 with extension kit. 800x400mm cutting area.
They are both set to 400.000. I’m assuming these are the dimensions of the cut area in the laser? If so how does it cut points beyond that I marked in the first picture?
