It’s happening again. It seems like the problem starts after I try to setup the roller. I’m on Absolute Coords. The laser fires and I can toggle it to position. It won’t frame or print a project. also, I’m still having problems getting the roller to function.
Homing
ok
Project loaded in 9 milliseconds
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
Starting stream
[MSG:Reset to continue]
Ortur Laser Master 2 Ready!
OLF 140.
Grbl 1.1h [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Okay, after a few resets it’s working again. I still can’t figure out the settings for the roller though.
It told you what the problem was.
But I have no idea where to access the G code.
In the terminal window.
If you want to see the GCode LightBurn emits, click ‘Save GCode’ next to the ‘Start’ button.
