Alarm 3 on Engraving TS2 Twotrees
I just to install my Twotrees TS2, but I have an error at the first test !!!
On Startup, I can see in the console window:
Waiting for connection…
ok
OK
[VER:1.1.2022070501:]
[OPT:PHSW]
[MSG:Using machine:LKS DLC32]
[MSG:Mode=AP:SSDI=Laser_15469:IP=192.168.4.1:MAC=24-D7-EB-23-6D-3D]
OK
Autoguiding
OK
I load a project
Project loaded in 0 milliseconds
I start to engrave (a rectangle 420x420mm Line mode 6000mm/min-40%)
Flow Start
Layer C02
(From the 0 position, the laser engraves on left Y axis, then X axis, then right Axis, then stop with the following error!!!)
ALARM:3
Reset on the move. Grbl cannot guarantee position. Lost steps are likely. A new autoguidance is strongly recommended.
Online or almost online 10:
Stream completed in 0:13
Grbl 1.1 [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
OK
I try an Autoguidance
OK
I start to engrave again, same error: ALARM:3
Thanks for your help
Roger
Best if you don’t do multiple posts.
Alarm 3 ar tricky
Try this for diagnostics
Unplug your laser head cable from the laser head
Run the same project, in absolute coordenates
WIll it finish - without errors - all motions?
This is not a multiple posts
There is an Alarm 3 and on other one about Alarm 9
