Sculpfun S10 krijgt alarm 3 wat moet ik doen
Sculpfun S10 gets alarm 3 what should I do
Ik heb zelf geen sculpfun maar kwam dit tegen op een ander forum, misschien heb je hier wat aan
mvg Hendrikjan
Dankjewel,
Ik zal eens kijken.
Gr Eric
That’s a very rare alarm code. What are you doing? Remember, the S10 has no limit switches and therefore cannot home, as long as you didn’t add some.
This is seen most often when a user accidentally selects the incorrect device type. Please ensure that you have a GRBL profile selected.
If you have a settings file (.lbset) or a device profile file (.lbdev) I can assist you with importing it.
Without either file, Open the Laser window and click the Devices button. Click the Find My Laser button. If that doesn’t work, click “Create Manually”
The next most common error is turning on Enable GCode Clustering - this switch should be turned off.
To confirm that it’s off, click Edit (along the top row), then Device settings (toward the bottom of the list).
It’s the second-last switch on the right. Turn it off, and click OK at the bottom of the Device Settings window.
Please let us know what you discover.
Ik heb contact gehad met sculpfun.
Zij zeggen dat het waarschijnlijk aan het moederbord ligt.
Wordt onderzocht
Grtz Eric
I have contacted sculpfun.
They say it’s probably the motherboard.
Under investigation
Greetings Eric
No offense, but hardware is usually not the cause of such errors. In my experience, it’s 95% user error, typically. So if you could provide some screenshots, we might be able to solve it as well. Sculpfun will be out of business for the next two weeks due to the Chinese holidays.
Beste,
Ik heb de fout gevonden en herstelt.
De fout onder in commando in gegeven en het werkte.
Thnx
Best,
I found the error and fixed it.
Entered the error at the bottom of the command and it worked.
Thnx
I do not follow, but I would like to know what the cure was.
Was the selected device type incorrect or was it related to GCode Clustering (in Device Settings)? (or something else?)
Returning here with a solution helps others on their Journey and helps us write documentation with greater clarity.
