Alarm 3 when fill mode is used
Hello everyone,
I have a Ortur Lasermaster 15W diode laser engraver.
So far I had no real problems with it but now I’m running into an issue that I can’t solve myself.
The engraving area of this mashine is 160x150mm. I want to mount the engraver to a wooden plate and engrave the working area with a 10mm raster so it would be easier for me to position things.
Additionally I placed so numbers 5,10,15 inside the working area.
I’m able to engrave the outside of the workingarea, but when it comes to the numbers inside the working area the laser stops and im getting the alarm 3 message. I found this post Consistent Alarm 3 but its not helping me because I thing my borders are sett correctly. I can engrave the outlines. so that should fit… right?
The program started to engrave number 15 first and this is the number furthes away from the center.
I figured out that Lightburn can engrave the numbers when the mode of the layer is set to line, but with line+fill, I’m getting the Alarm 3.
Stream wird gestartet
ALARM:3
Auf oder in der Nähe der Linie 86:
Stream fertiggestellt in 0:02
ok
Ortur Laser Ready!
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
What could I do?
Thanks for your help :slight_smile:
Alarm:3 is a reset while in motion. Can you post the GCode generated for that file? (click Save GCode, save it as a text file, and attach the file here to the post)
Hello Again,
sorry thats my bad. :slight_smile: I was testing and uploaded the wrong code.
Thank you for helping me :slight_smile:
; LightBurn 0.9.11
; GRBL-M3 (1.1e or earlier) device profile, absolute coords
G00 G17 G40 G21 G54
G90
; Scan+Cut @ 30 mm/sec, 100% power
M8
M5
G0X150.3Y0.48
G91
M3
G1X0.75F1800S0
G1X0.28S1000
G1X0.67S0
G1X0.81S1000
G1X0.75S0
G1X0.18Y0.2S0
G1X-0.75S0
G1X-1.18S1000
G1X-0.48S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.48S0
G1X0.27S1000
G1X0.65S0
G1X0.26S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.26S1000
G1X-0.65S0
G1X-0.27S1000
G1X-0.48S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.48S0
G1X0.27S1000
G1X0.65S0
G1X0.26S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.26S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.26S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.26S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.26S1000
G1X0.75S0
G1X-0.02Y0.2S0
G1X-0.75S0
G1X-1.15S1000
G1X-0.49S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.5S0
G1X0.26S1000
G1X0.75S0
G1X0.01Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.5S0
G1X-0.38S1000
G1X-0.75S0
G1X0.04Y0.2S0
G1X0.75S0
G1X0.34S1000
G1X0.51S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.51S0
G1X-0.31S1000
G1X-0.75S0
G1X0.04Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.52S0
G1X0.27S1000
G1X0.75S0
G1X0.85Y0.2S0
G1X-0.75S0
G1X-1.12S1000
G1X-0.52S0
G1X-0.24S1000
G1X-0.75S0
G1X-150.37Y47S0
G1X0.75S0
G1X1.09S1000
G1X0.75S0
G1X0.05Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.64S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.64S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.64S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.64S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.75S0
G1X-0.91Y0.2S0
G1X0.75S0
G1X1.18S1000
G1X0.75S0
G1X-0.1Y0.2S0
G1X-0.75S0
G1X-1.07S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.26S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.75S0
G1X0.01Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X1.13S1000
G1X0.75S0
G1X0.78Y47S0
G1X-0.75S0
G1X-1.1S1000
G1X-0.57S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.49S0
G1X0.28S1000
G1X0.7S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.7S0
G1X-0.28S1000
G1X-0.49S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.49S0
G1X0.28S1000
G1X0.7S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.7S0
G1X-0.28S1000
G1X-0.49S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.49S0
G1X0.28S1000
G1X0.7S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.7S0
G1X-0.28S1000
G1X-0.49S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.49S0
G1X0.28S1000
G1X0.7S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.7S0
G1X-0.28S1000
G1X-0.49S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.49S0
G1X0.28S1000
G1X0.7S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.7S0
G1X-0.28S1000
G1X-0.49S0
G1X-0.27S1000
G1X-0.75S0
G1X-0.1Y0.2S0
G1X0.75S0
G1X0.37S1000
G1X0.49S0
G1X0.28S1000
G1X0.7S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.7S0
G1X-0.28S1000
G1X-0.49S0
G1X-0.33S1000
G1X-0.75S0
G1X0.03Y0.2S0
G1X0.75S0
G1X0.3S1000
G1X0.49S0
G1X0.28S1000
G1X0.7S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-1.24S1000
G1X-0.5S0
G1X-0.26S1000
G1X-0.75S0
G1X0.04Y0.2S0
G1X0.75S0
G1X0.22S1000
G1X0.66S0
G1X0.9S1000
G1X0.75S0
G1X97.04Y-102.8S0
G1X0.75S0
G1X0.28S1000
G1X0.68S0
G1X0.86S1000
G1X0.75S0
G1X0.2Y0.2S0
G1X-0.75S0
G1X-1.25S1000
G1X-0.49S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.49S0
G1X0.27S1000
G1X0.71S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.71S0
G1X-0.27S1000
G1X-0.49S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.49S0
G1X0.27S1000
G1X0.71S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.71S0
G1X-0.27S1000
G1X-0.49S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.49S0
G1X0.27S1000
G1X0.71S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.71S0
G1X-0.27S1000
G1X-0.49S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.49S0
G1X0.27S1000
G1X0.71S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.71S0
G1X-0.27S1000
G1X-0.49S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.49S0
G1X0.27S1000
G1X0.71S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.71S0
G1X-0.27S1000
G1X-0.49S0
G1X-0.38S1000
G1X-0.75S0
G1X0.04Y0.2S0
G1X0.75S0
G1X0.34S1000
G1X0.49S0
G1X0.27S1000
G1X0.71S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.71S0
G1X-0.27S1000
G1X-0.49S0
G1X-0.31S1000
G1X-0.75S0
G1X0.04Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.49S0
G1X0.27S1000
G1X0.71S0
G1X0.27S1000
G1X0.75S0
G1X-0.07Y0.2S0
G1X-0.75S0
G1X-1.11S1000
G1X-0.56S0
G1X-0.24S1000
G1X-0.75S0
G1X-49.49Y-3S0
G1X0.75S0
G1X0.8S1000
G1X0.75S0
G1X0.19Y0.2S0
G1X-0.75S0
G1X-1.18S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.64S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.64S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.64S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.75S0
G1X-0.03Y0.2S0
G1X-0.75S0
G1X-1.14S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.26S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.27S1000
G1X0.75S0
G1X0.01Y0.2S0
G1X-0.75S0
G1X-0.27S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.75S0
G1X0.85Y0.2S0
G1X-0.75S0
G1X-1.12S1000
G1X-0.75S0
G1X99.6Y-2S0
G1X0.75S0
G1X0.28S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.28S1000
G1X-0.75S0
G1Y0.2S0
G1X0.75S0
G1X0.28S1000
G1X0.75S0
G1Y0.2S0
G1X-0.75S0
G1X-0.28S1000
G1X-0.75S0
G90
M5
G0X150.93Y2.58
M3
G1X151.05S1000F720
G1Y0.47
G1X151.33
G1Y3.53
G1X151.1
G1X150.93Y2.58
M5
G0X151.82Y2.15
M3
G1X152.73
G1Y0.71
G1X152.08
G1Y1.46
G1X151.81
G1Y0.69
G1Y0.62
G1X151.84Y0.57
G1X151.89Y0.52
G1X151.94Y0.49
G1X152.03Y0.47
G1X152.78
G1X152.87Y0.49
G1X152.92Y0.52
G1X152.96Y0.57
G1X152.99Y0.62
G1Y0.69
G1Y2.17
G1Y2.24
G1X152.96Y2.3
G1X152.92Y2.34
G1X152.87Y2.38
G1X152.78
G1X152.09
G1X152.12Y3.29
G1X152.97
G1Y3.53
G1X151.85
G1X151.82Y2.15
M5
G0X103.07Y3.31
M3
G1Y3.37
G1X103.03Y3.43
G1X102.99Y3.48
G1X102.94Y3.51
G1X102.85Y3.53
G1X102.04
G1X101.97
G1X101.92Y3.49
G1X101.87Y3.45
G1X101.83Y3.4
G1X101.82Y3.31
G1Y0.69
G1Y0.62
G1X101.85Y0.56
G1X101.9Y0.52
G1X101.95Y0.49
G1X102.04Y0.47
G1X102.85
G1X102.94Y0.49
G1X102.99Y0.52
G1X103.03Y0.56
G1X103.06Y0.62
G1Y0.69
G1Y3.31
M5
G0X101.33Y3.53
M3
G1X101.1
G1X100.93Y2.58
G1X101.05
G1Y0.47
G1X101.33
G1Y3.53
M5
G0X52.57Y3.53
M3
G1X51.45
G1X51.42Y2.15
G1X52.32
G1Y0.71
G1X51.68
G1Y1.46
G1X51.41
G1Y0.69
G1Y0.62
G1X51.44Y0.56
G1X51.48Y0.52
G1X51.54Y0.49
G1X51.62Y0.47
G1X52.37
G1X52.46Y0.49
G1X52.56Y0.57
G1X52.59Y0.69
G1Y2.17
G1X52.56Y2.29
G1X52.46Y2.38
G1X52.37
G1X51.68
G1X51.72Y3.29
G1X52.57
G1Y3.53
M5
G0X1.73Y50.41
M3
G1X1.83Y50.49
G1X1.86Y50.61
G1Y52.1
G1X1.82Y52.22
G1X1.73Y52.3
G1X1.64Y52.31
G1X0.95
G1X0.98Y53.21
G1X1.84
G1Y53.45
G1X0.72
G1X0.68Y52.07
G1X1.59
G1Y50.63
G1X0.95
G1Y51.39
G1X0.68
G1Y50.61
G1Y50.54
G1X0.71Y50.49
G1X0.75Y50.44
G1X0.8Y50.41
G1X0.89Y50.39
G1X1.64
G1X1.73Y50.41
M5
G0X1.66Y100.22
M3
G1X2.47
G1X2.56Y100.24
G1X2.62Y100.27
G1X2.66Y100.32
G1X2.69Y100.37
G1Y100.44
G1Y103.06
G1Y103.13
G1X2.66Y103.19
G1X2.62Y103.23
G1X2.56Y103.27
G1X2.47Y103.28
G1X1.66
G1X1.6
G1X1.54Y103.25
G1X1.49Y103.21
G1X1.46Y103.15
G1X1.44Y103.06
G1Y100.44
G1Y100.37
G1X1.48Y100.32
G1X1.52Y100.27
G1X1.58Y100.24
G1X1.66Y100.22
M5
G0X1.72Y100.46
M3
G1Y103.04
G1X2.42
G1Y100.46
G1X1.72
M5
G0X0.95Y100.22
M3
G1Y103.28
G1X0.73
G1X0.56Y102.34
G1X0.68
G1Y100.22
G1X0.95
M5
G0X102.09Y3.29
M3
G1X102.8
G1Y0.71
G1X102.09
G1Y3.29
; Cut @ 10 mm/sec, 100% power
M8
M5
G0X82Y77
M3
G1X78Y73F600
M5
G0X0.02Y75
M3
G1X160
M5
G0X159.98Y149.98
M3
G1Y0.02
G1X0.02
G1Y149.98
G1X159.98
M5
G0X107.96Y116.46
M3
G1X108.94Y115.78
G1X109.92Y115.07
G1X110.87Y114.34
G1X111.8Y113.58
G1X112.72Y112.81
G1X113.62Y112.01
G1X114.5Y111.19
G1X115.36Y110.36
G1X116.19Y109.5
G1X117.01Y108.62
G1X117.81Y107.72
G1X118.58Y106.8
G1X119.34Y105.87
G1X120.07Y104.92
G1X120.78Y103.94
G1X121.46Y102.96
G1X122.12Y101.95
G1X122.76Y100.93
G1X123.38Y99.89
G1X123.97Y98.83
G1X124.53Y97.76
G1X125.07Y96.68
G1X125.58Y95.58
G1X126.07Y94.46
G1X126.53Y93.33
G1X126.97Y92.19
G1X127.37Y91.04
G1X127.75Y89.87
G1X128.1Y88.69
G1X128.43Y87.5
G1X128.72Y86.29
G1X128.98Y85.08
G1X129.22Y83.85
G1X129.42Y82.61
G1X129.6Y81.37
G1X129.74Y80.11
G1X129.85Y78.85
G1X129.93Y77.57
G1X129.98Y76.29
G1X130Y75
G1X129.98Y73.71
G1X129.93Y72.43
G1X129.85Y71.15
G1X129.74Y69.89
G1X129.6Y68.63
G1X129.42Y67.39
G1X129.22Y66.15
G1X128.98Y64.92
G1X128.72Y63.71
G1X128.43Y62.5
G1X128.1Y61.31
G1X127.75Y60.13
G1X127.37Y58.96
G1X126.97Y57.81
G1X126.53Y56.67
G1X126.07Y55.54
G1X125.58Y54.42
G1X125.07Y53.32
G1X124.53Y52.24
G1X123.97Y51.17
G1X123.38Y50.11
G1X122.76Y49.07
G1X122.12Y48.05
G1X121.46Y47.04
G1X120.78Y46.06
G1X120.07Y45.08
G1X119.34Y44.13
G1X118.58Y43.2
G1X117.81Y42.28
G1X117.01Y41.38
G1X116.19Y40.5
G1X115.36Y39.64
G1X114.5Y38.81
G1X113.62Y37.99
G1X112.72Y37.19
G1X111.8Y36.42
G1X110.87Y35.66
G1X109.92Y34.93
G1X108.94Y34.22
G1X107.96Y33.54
G1X106.95Y32.88
G1X105.93Y32.24
G1X104.89Y31.62
G1X103.83Y31.03
G1X102.76Y30.47
G1X101.68Y29.93
G1X100.58Y29.42
G1X99.46Y28.93
G1X98.33Y28.47
G1X97.19Y28.03
G1X96.04Y27.63
G1X94.87Y27.25
G1X93.69Y26.9
G1X92.5Y26.57
G1X91.29Y26.28
G1X90.08Y26.02
G1X88.85Y25.78
G1X87.61Y25.58
G1X86.37Y25.4
G1X85.11Y25.26
G1X83.85Y25.15
G1X82.57Y25.07
G1X81.29Y25.02
G1X80Y25
G1X78.71Y25.02
G1X77.43Y25.07
G1X76.15Y25.15
G1X74.89Y25.26
G1X73.63Y25.4
G1X72.39Y25.58
G1X71.15Y25.78
G1X69.92Y26.02
G1X68.71Y26.28
G1X67.5Y26.57
G1X66.31Y26.9
G1X65.13Y27.25
G1X63.96Y27.63
G1X62.81Y28.03
G1X61.67Y28.47
G1X60.54Y28.93
G1X59.42Y29.42
G1X58.32Y29.93
G1X57.24Y30.47
G1X56.17Y31.03
G1X55.11Y31.62
G1X54.07Y32.24
G1X53.05Y32.88
G1X52.04Y33.54
G1X51.06Y34.22
G1X50.08Y34.93
G1X49.13Y35.66
G1X48.2Y36.42
G1X47.28Y37.19
G1X46.38Y37.99
G1X45.5Y38.81
G1X44.64Y39.64
G1X43.81Y40.5
G1X42.99Y41.38
G1X42.19Y42.28
G1X41.42Y43.2
G1X40.66Y44.13
G1X39.93Y45.08
G1X39.22Y46.06
G1X38.54Y47.04
G1X37.88Y48.05
G1X37.24Y49.07
G1X36.62Y50.11
G1X36.03Y51.17
G1X35.47Y52.24
G1X34.93Y53.32
G1X34.42Y54.42
G1X33.93Y55.54
G1X33.47Y56.67
G1X33.03Y57.81
G1X32.63Y58.96
G1X32.25Y60.13
G1X31.9Y61.31
G1X31.57Y62.5
G1X31.28Y63.71
G1X31.02Y64.92
G1X30.78Y66.15
G1X30.58Y67.39
G1X30.4Y68.63
G1X30.26Y69.89
G1X30.15Y71.15
G1X30.07Y72.43
G1X30.02Y73.71
G1X30Y75
G1X30.02Y76.29
G1X30.07Y77.57
G1X30.15Y78.85
G1X30.26Y80.11
G1X30.4Y81.37
G1X30.58Y82.61
G1X30.78Y83.85
G1X31.02Y85.08
G1X31.28Y86.29
G1X31.57Y87.5
G1X31.9Y88.69
G1X32.25Y89.87
G1X32.63Y91.04
G1X33.03Y92.19
G1X33.47Y93.33
G1X33.93Y94.46
G1X34.42Y95.58
G1X34.93Y96.68
G1X35.47Y97.76
G1X36.03Y98.83
G1X36.62Y99.89
G1X37.24Y100.93
G1X37.88Y101.95
G1X38.54Y102.96
G1X39.22Y103.94
G1X39.93Y104.92
G1X40.66Y105.87
G1X41.42Y106.8
G1X42.19Y107.72
G1X42.99Y108.62
G1X43.81Y109.5
G1X44.64Y110.36
G1X45.5Y111.19
G1X46.38Y112.01
G1X47.28Y112.81
G1X48.2Y113.58
G1X49.13Y114.34
G1X50.08Y115.07
G1X51.06Y115.78
G1X52.04Y116.46
G1X53.05Y117.12
G1X54.07Y117.76
G1X55.11Y118.38
G1X56.17Y118.97
G1X57.24Y119.53
G1X58.32Y120.07
G1X59.42Y120.58
G1X60.54Y121.07
G1X61.67Y121.53
G1X62.81Y121.97
G1X63.96Y122.37
G1X65.13Y122.75
G1X66.31Y123.1
G1X67.5Y123.43
G1X68.71Y123.72
G1X69.92Y123.98
G1X71.15Y124.22
G1X72.39Y124.42
G1X73.63Y124.6
G1X74.89Y124.74
G1X76.15Y124.85
G1X77.43Y124.93
G1X78.71Y124.98
G1X80Y125
G1X81.29Y124.98
G1X82.57Y124.93
G1X83.85Y124.85
G1X85.11Y124.74
G1X86.37Y124.6
G1X87.61Y124.42
G1X88.85Y124.22
G1X90.08Y123.98
G1X91.29Y123.72
G1X92.5Y123.43
G1X93.69Y123.1
G1X94.87Y122.75
G1X96.04Y122.37
G1X97.19Y121.97
G1X98.33Y121.53
G1X99.46Y121.07
G1X100.58Y120.58
G1X101.68Y120.07
G1X102.76Y119.53
G1X103.83Y118.97
G1X104.89Y118.38
G1X105.93Y117.76
G1X106.95Y117.12
G1X107.96Y116.46
M5
G0X78Y77
M3
G1X82Y73
M5
M9
G1S0
G90
; return to user-defined finish pos
G0 X0 Y0
M2
I can’t see anything special about the lines around line 86 that would cause this to fail, however it’s possible that the laser tripped an error shortly before.
No, not really - you have overscan enabled for this, so the fill moves travel outside the outline. If you have the numbers placed very close to the sides of the machine, this could be the problem.
