Alarm: 9 Could not find limit switch
Hi All,
I was using my rotary yesterday and went to reload my regular settings today and am getting the below homing error on my k40+.
I’ve tried to reload setting multiple times, made the sure rotary is off, the Y axis is plugged back in, restarted and updated Lightburn to no avail. When I try to home, it doesn’t move at all, then I get the below. Any help would be appreciated!
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
Homing fail.
ok
Grbl 1.1h [‘$’ for help]
omtech
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Both axis do not move when trying to home? Do the move buttons work?
neither axis moves, when I try to use the move buttons, it says busy, waits 10 seconds then says stream completed but it doesnt go anywhere
Sounds like a more basic issue. Both axis do not work?
