Alarm 9 Homing fail error
I assembled my laser engraver using CNC Shield and GRBL, I have already tested cutting and engraving, everything works. But as soon as I connected the limit switches, it stopped driving. When idle, I click on the limit switches and the program writes “ALARM: 1
A hard limit has been triggered. The machine’s position is likely lost due to the sudden and immediate stop. Re-targeting is strongly recommended.” Both limit switches work, but after $H it doesnt move and the console displays “ALARM:9
Pointing error. The limit switch could not be found within the search distance. Defined as 1.5 * max_travel during search and 5 * offset during search stages.
ok”
My $$
$0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=1
$24=25.000
$25=100.000
$26=244
$27=6.000
$30=1000
$31=0
$32=1
$100=100.000
$101=100.000
$102=100.000
$110=400.000
$111=400.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=500.000
$131=500.000
$132=200.000
Looks like the switches are recognized to be activated all the time. Try to invert them ($5=1). You can test by sending a question mark “?” in the console window and check the output. There is a section Pn: which shows the activated limit switches.
I checked
With 5=0
<Idle|MPos:0.000,0.000,300.000|FS:0,0|WCO:0.000,0.000,0.000>
With 5=1
<Idle|MPos:0.000,0.000,300.000|FS:0,0|Pn:XYZ|Ov:100,100,100>
When i set $5=1, then i have another error
“ALARM:8
Pointing error. During the cycle, it was not possible to reset the limit switch when moving. Try increasing the tap setting or check the wiring.
ok”
I just read your post again and I got it wrong. Your setting was correct and the output shows that all switches work. So $5=0 is correct. If you hit the switches and get the hard stop message, that’s fine and should be like this. Be aware, that after a hard limit trigger event, you probably need to power cycle the board to make it work again.
Regarding homing:
You set a workspace size of 500x500, is that correct? Your speeds are extremely slow compared to that size. Which driving mechanism do you use? If it is a standard mechanics, set
$24=50
$25=1000
$110=5000
$111=5000
$120=500
$121=500
Since you are driving such slow, you might run in a timeout.
Slow speed for safety only.
When i hit “home” button - nothing happens. The motors “knock” once, entering hold mode, but do not move.
Then my next guess would be that the motors don’t get enough power to run simultaneously. But you said you tested normal movement already?
Yep, i already cut and engrave some plywood, they works normal (with turned off hard limits), problem only with homing + hard/soft limits (G28, $H doesnt matter it always says the same)
Ah, another idea. Which firmware version did you use? Standard grbl from the GitHub repository? Or something else? Maybe it tries to home Z first. Check if you can home a single axis via $HX or $HY (but the single commands also need to be enabled in firmware).
Thanks for the hint!
Redact config.h in the GRBL firmware
#define HOMING_CYCLE_0 (1<<Z_AXIS)
#define HOMING_CYCLE_1 ((1<<X_AXIS)|(1<<Y_AXIS))
To:
#define HOMING_CYCLE_0 (1<<X_AXIS)
#define HOMING_CYCLE_1 (1<<Y_AXIS)
And now homing works perfect
Great! Though, I’d change it to
#define HOMING_CYCLE_0 ((1<<X_AXIS)|(1<<Y_AXIS))
This will make both axis home simultaneously, instead of one after another.
