Why do i get this position when starting a project?
X in -200
Y in - 200
Is your home position front left and do you have limit switches for homing position?
Yes, that is them. The reason you show the negative numbers is that you are using the machine in the negative quadrant. I use the front left on my machine. Hopefully someone who uses their machine with the same home position can help you out more than I can.
You should read through the documentation. There is probably some information there for you. The LightBurn software is the best and the documentation covers almost everything.
