ALERT:9 Homing failed - At startup & Home button
Hi all,
I have a fairly new Atomstack A10 pro v2 that works good, I can move the laser module arround with the move buttons, it cuts & engraves without any problems.
However at startup and when clicking the home button - homing is failed. I can hear that the motor starts buzzing, but mo movement. When the motor is buzzing the laser module is locked and cannot be moved. Limit switches are installed and beeps when beeing manually pushed.
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
[MSG:alarmCodeCodeIntHandle:9]
ok
Grbl C10-0109-V1003 [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Other:
RGBL
Laptop - Win 10
LB 1.6.03
Thanks for your help
