AlgoLaser Alpha 22W not responding after latest LightBurn update
Hello,
I updated LightBurn to the latest version and after the update my AlgoLaser Alpha 22W stopped responding correctly. The air assist compressor turns on, but the machine does not move at all. I cannot use the Frame function, cannot move the laser module manually, and cannot send the module back to origin/home position.
After uninstalling the new version and reinstalling my previous LightBurn version, everything started working normally again.
It seems the latest LightBurn update may have a compatibility or communication issue with the AlgoLaser Alpha 22W.
Has anyone experienced the same problem or found a solution?
Hi Ahmet,
Can you copy and paste what is reported in the Console tab in LightBurn so we can see what the machine is communicating back to us when operating?
teşekkür ederim. eski sürümü tekrar yükleyip sorunumu çözdüm. ama yeni sürümü de kullanmak istiyorum. yarın yeni sürümü yükleyip rapor bildireceğim.
Thank you. I reinstalled the old version and solved my problem. But I also want to use the new version. I will install the new version tomorrow and submit a report.
Looking forward to it.
Thanks!
