Align . . . Next to Each Other?
There are helpful commands to align left/right, top/bottom/ and center.
But is there a way to get the right side of an object to align with the left side of an object . . . or the top of one object to align to the bottom of another?
Or . . . if two objects could be aligned next to each other at a distance of “x” millimeters?
These would help make the most efficient use of space . . . and in the case of two such aligned rectangles, only a single pass cut could be made for the side they have in common.
To move object together, use Arrange : Distribute
But plan your work / job execution to eliminate overlapping lines if you choose to do this. Otherwise there will be no time saved AND you will most likely char / melt the work piece. Also keep in mind when you double up a cut line, the effect of the kerf on the part size may be different to an object sharing a line than to an object independently cut.
Cool! Thanks so much.
