Have a Wizmaker Camera, Setup on my bed, alignment was spot on. When I put my honeycomb cutting bed in (.75in tall) it appears to shift the field of view of the camera where if I position something it no longer aligns to the display. Do I need to run an alignment for each a 3mm flat sheet on my bed and a seperate one when I use my honeycomb? Is there a way to save parameters for each so as not to redo it each time?
If it is to be accurate, then the focus must be the same as during calibration. I don’t mean you can save different camera profiles, but you can create a complete copy of your machine with the other camera setup. Switching between the 2 is practically no problem.
