With the latest “upgrade” to Lightburn (1.3.01), any shape (elipse, rectangle, polygon, etc.) have a segment missing that does not burn in LINE mode. So, I can’t cut out anything. Does someone have an explanation and/or a work around? THANK YOU!
Perhaps Tabs
is turned on for that cutting layer, with a generous tab width and only a single tab per shape?
Or Perforation
mode is in full effect, with large skips?
Upload an offending project so we can all take a look at it.
THANK YOU! Found out it is happening in previous versions of Lightburn, as well. Not sure what I have done to change things. The problem appears in new test projects, too, if I just add a shape and check it in preview. THANK YOU!!!
Circle Design Test V1 Logo and Doves.lbrn2 (87.3 KB)
Those are the hardest errors to find, but the easiest to fix.
You can turn Tabs
off in the cut layer properties, then click the Make Default
button so the next time you use that layer, you get what you want:
I found the setting that you spoke of. That fixed it. Not sure how I activated the “TABS,” but apparently, I did. THANK YOU!!
