All objects suddenly burned in the lower left corner
Hi,
I’m using your S30 Pro Max with 20 Watt together with Lightburn.
System worked very well the last days. Trying to work with the system this afternoon again (nothing changed on computer system since) I am not able to position laser for engraving / cutting. HOME is working and I can move to any single point im trying to move to. But all objects on drawing seems to be in the left corner now. Whatever I change on the drawing, the laser cuts only on the left corner.
I also deleted the laser and re-connected it (successfully) but nothing changes.
Can you help me? If it helps to understand in a better way, I can also post a video.
Best regards
Alex Fischer
Change the Start From mode from User Origin to Absolute Coords in Laser window.
