We have 100s of programs set up with the black layer having various sets of automatic tabs (depending on the machine we use, we have different tab dimensions).
I updated to 1.20 a couple weeks ago. Today I went to open a few of my programs (saved in a dropbox) and ALL my black-layer tabs are gone. All of them have tabs unchecked. Every single program is like this. Every single one.
In fact, I just re-tabbed a file, saved it, and then when re-opened it the tabs were turned off again.
Please tell me this is just a setting I accidently have on and not that 1.2 just wiped out about 3 years of work
I believe this to be a known bug, the following is a response from the dev’s
The tabs are still there but accidentally disabled. If you open the cut settings dialog for the layers in question you can re-enable the tabs with the “Tabs / Bridges” checkbox. It’s just a bug with loading the file - it has been fixed as of this morning and won’t be a problem anymore after the next patch release - which will likely be soon.
Thank you. I did revert back to 1.1.04 and the tabs appear again. My mfg group is not capable of turning tabs on and off so I have to make sure what they open is the final version
