An idea for lightburn
I have been using Lightburn for just over a year now and I’m happy with it . I like how easy it is to use and many other features. The one feature that is helpful is the way i can turn something 90 degrees, but sometimes I’m not exactly perfect and i need to fiddle with the shape to get it perfect.
Is there a way for me to be more accurate I was thinking a box that pops up when turning the part i can type the degree i want and the part would go to that degree?
Thank you for reading my Question
Well I must say I feel rather stupid right now I went back to my Lightburn page and there it was the box I could type the exact degree and the part jump right whare i want it
An even faster way is to use the comma or period key. One turns the selected item 90 degrees clockways, the other 90 counterclockwise. If you hold the shiftkey it rotates 45 degrees.
If there’s a line that should be parallel to an axis, you can hit A while hovering over the line in Edit Nodes to align it:
That will yoink the whole figure along with it, which is probably what you want.
