When I want to open lightburn, this keeps popping up.
can I do something so that this does not happen again, this is very annoying.
Any help would be appreciated.
At some point you created a material library, then moved or deleted it. LightBurn is telling you that it can’t find it.
Open the material library window, click ‘New’, then close LightBurn. It will remember that the last library you were using was none at all, and the message will go away.
Thank you but I don’t know what you mean by the material library window I have a lot to learn
It worked! I found a topic that asked me how to find the material library. thank you very much.
