I cut out alot of jiggs for various things. I generally design my jiggs in Illustrator and create the 1st original template, then use the Distort and Transform tool to replicate that original, across the page so i only need to work off the original to make adjustments to the entire set.
Since obtaining a new laser, i can now manufacture my own jiggs. I tried to dump an .AI with a jigg setup on it in LightBurn and it simply crashed.
So i tried something else. I rasterised the jigg in AI, then exported as a transparent background PNG, dropped it as an image into LightBurn, did image trace and it works ok, some circles have got flat sides (so if anyone knows how to straighten these out, might just stick with this method)
However seeing as LightBurn is already quite powerful, considering you can plot the shape on the co-ords you want, other than duplicating, is there a similiar function to create clones of the original, like the Transform tool in AI?
Or is there another method im missing all together ?
Thanks
