Any guys know what's these IO port means?
Please check these numbers in the picture, 0-15, I’m new to this, I just knew the pedal should be wired to 14, but what does the rest mean? Any special function?
Just curious
IO ports
have you rerad the documentation on this?
The Red Dot probably turns on a visible aiming pointer.
You could set up a stack light with the Ready and Busy outputs. If there’s an Error output, make it the red light on top:
https://www.amazon.com/LUBAN-Industrial-Rotatable-Flashing-Switchable/dp/B086ZJNLBX/
Full-frontal industrial!
