Any way to connect via Repetier Server
Hi there.
I am new to the forum, however, I’ve been using Lightburn for quite some time with my Ortur based system. This system started life as an Ortur LM1, but I have modified it with a larger print area and a 40W laser Tree diode laser.
I have recently built a Lowrider 3 CNC machine, with Marlin firmware on a BTT SKR Pro controller. I have attached a 40W Laser Tree unit to it, and want to control the laser with Lightburn. I can get a connection to the machine through the serial port, but only by disabling Repetier Server, which I use to run the CNC (through Repetier Host which connects through the server rather than connecting directly).
Is there any way of getting Lightburn to use Repetier Server as the connection to my machine, rather than connecting to Marlin directly through the serial port?
