I have a BLU100 lotus laser that uses what appears to be a customised variant of RDCAM on their own version of a RUIDA controller. I greatly prefer Lightburn and want to use it directly but the file formats dont match. If the controller really is a RUIDA under the skin then i believe it is possible to configure it to do so. I wonder if i am the only person with this specific setup.
What options guys.
The file format it needs is either .rld or .rd as standard
RLD and RD are the normal RDWorks file formats. If you can use their stock software to draw a square and click “Save to UFile”, then send me that, I can tell you if it’s customized at all and whether LightBurn would work for it. There’s a decent chance it will without changes.
Hi Ray
I discovered that Lightburn has the ’ save to rd’ option. For some reason i had not noticed this before. It works perfectly and preserves all of the layer properties. I have made some test cuts and all looks perfect.
I will stick with using Lightburn and ignore their ‘Lasercut’ supplied option.
Thanks
keith
