Anyway to create cut files for dif top/bottom circumference obj
I have some vase shaped mugs that are skinny on bottom and larger on top. Wanting to try full wrap seemless designs. Can not find any info and the rotary setup doenst seem to have fileds for this?
You don’t mention if you’re using a roller, 4 wheel, or chuck rotary. How you handle it depends on the rotary type.
If it is a straight taper, Lightburn has a Tool for that. If it is a curved body vase, you will get a matching ends wrap only in a very narrow band.
What is the tool called? It is straight tapered cups. I didnt see anything under rotary.
Adjustable ends 4 wheel rotary.
It’s called the taper warp tool. I believe it’s under the laser tools menu. I’m out and about and can’t confirm that location.
