Hello everyone,
We are using Linux Mint 21.2 and LightBurn 1.5.01 as AppImage. For the user, tty and dialout are activated and LightBurn basically works as it should. The communication with USB or with the laser works.
Now we wanted to control a webcam in order to integrate it into LIghtBurn. The webcam works, we get a camera image with board tools (e.g. Cheese).
The camera also appears with its name in LightBurn, but unfortunately no image is displayed. If you start the AppImage from the console, the following error is displayed:
gast@mlr-aio115 ~/.lightburn % ./LightBurn-Linux64-v1.5.01.AppImage :(
Using the core prefs dir
connected
"enp0s31f6" "enp0s31f6"
"wlp2s0" "wlp2s0"
"Integrated_Webcam_FHD: Integrat" "/dev/video0"
"MicroTop: MicroTop" "/dev/video2"
Setting camera to "/dev/video0"
/usr/lib/x86_64-linux-gnu/gio/modules/libgiognutls.so: undefined symbol: g_tls_channel_binding_error_quark
Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgiognutls.so
Error: cannot create camera service, the 'camerabin' plugin is missing for GStreamer 1.16.
Please install the 'bad' GStreamer plugin package.
If I understand appimage correctly, everything necessary for lightburn is already supplied in a container. So the plugin “camerabin” for GStreamer should also be installed, correct?
I have also installed this locally on Linux Mint (or Linux Mint already had this pre-installed) but this has not brought any change.
Is the plugin missing in the AppImage? How can I check this?
Regards
Timo
