Are these features going to be added?
Is there a way to remove nodes with a command and not alter the shape drastically? I have other software that allows me to rebuild a curve. Also is there a command for mirroring around center or object? Very handy feature for designing.
Edit->Optimize selected shapes
Can you clarify? Do you mean a tool that allows you to draw one side of a bilateral split and the other side is automatically mirrored as you draw? If so, then no, I’m not aware of such a feature in LightBurn.
However, if you mean the ability to duplicating a shape around another object then yes, use the circular array tool in the left side toolbar.
