My art library, when I open it, the top section is not red and it will not activate import graphic from project. I just purchased lightburn
3 things that are required:
- You must have created a library. If none exists, push New to create a library
- Once created, select the library on the left window pane
- Once the library is selected, select a graphic from your project by clicking it. “Import graphic from project” should then become available. Push that to add to library.
