Art library just floating around ,
High all, when I tick the art library button I get a floating window. However it doesn’t seem to become a fixed window on the bottom right or a tab, any ideas? Hope I’ve explained my issue enough. Thanks.
I shall try that this evening. Thank you :blush:
This was produced some time ago, yet the concepts remain the same. :slight_smile:
Reset the window layout - LightBurn Tips - LightBurn Software Documentation
Sometimes a window gets shoved off the screen or positioned in a way that makes it hard to find, or move. You can reset the window layout in LightBurn in two different ways:
  • In the Window menu, choose “Reset to default layout”. This will undock all windows, and re-dock them in the default order.
  • If that doesn’t do it, restart LightBurn while holding the Shift key - this skips restoring the saved window layout, and always works.
Thanks for the help, all sorted now.
