Artlume t1 setup
I am setting an up an artlume t1 and am having trouble getting it to move the right directions. I have tried all the $3 commands and nothing has worked. I have also removed and installed from scratch. Any ideas or videos
This is most often cause by not having the correct corner selected for the Home position. Front-left is most common, but for your laser I do not know. If it does not have limit switches there is no Home, but it is the Origin wherever the module is sitting when powered up.
On your machine, I would expect the corner marked with “X” would be the Front Left corner.
Let us know where it does Home if enabled.
