Aspect ratio is changing when sent to laser
My width is always good but the height is always short.
I have a Longer Ray5 20w
I have not installed the rotary yet
Belts are tensioned
When confirming settings $$ 101 is set to 56
Help Please
This is kind of an odd value. Are you sure that is correct? Anyhow, if this value leads to wrong sizes, adjust it.
The only info i had for the Ray5 was to use 56. What is your recommendation?
This is the steps/mm value. Your mechanics has a specific driving mechanism, and a very common ratio is 80 steps/mm. But 56 can also be correct, depending on mechanical setup. Usually both axis have the same ration, what is set at $100?
$100 - 80.0
Then change $101 also to 80 and test again.
This corrected the issue. Thank you
