I’ve had my Atezr 36w for about 3 months now. I’ve noticed that when I cut wood and/or leather (using Lightburn) the laser leaves a lightly engraved line about 1-2mm from the actual cut line. I haven’t noticed this until recently. It sounds like an alignment issue, but not sure where to start. For my wood projects I just lightly sand the piece to remove the line, but it’s becoming a problem with the leather patches that I make. Any advice would be appreciated!
Could you post a image showing the problem please?
If you are using grayscale image, make sure MIN is 0%
ALso make sure your $31 value is 0
I will post images this afternoon. Thanks for the response.
