Hi, I’m using an Atezr P10w Combo with the included KR Standard Roller Rotary, and you can’t read the screenshots in the manual they are blurred, and all the guidance I can find for the settings are 50mm per rotation and 16mm Roller Diameter, but when I ran my initial burn test it barely rotated the material and burned it in almost a single line. I then ran a rotary test and realized it only rotated 50% so I bumped up the setting to 100 mm per, and it test rotated all the way around, but when I did another test engrave it barely rotated again, so I just kept bumping up the rotation mm setting, I finally ended up bumping the rotation all the way to 1275mm per rotation and finally almost got a perfect burn.
Does this sound normal, and/or is it just something you have to continually play with or am I doing something wrong?
Thanks
References:
Learn how to set up ATEZR KR PRO with LightBurn for laser engraverprojects - Step-by-Step Tutorial - YouTube
Atezr Rotary Attachment Lightburn Parameters | Hoffman Engineering
