Atomstack 10 Pro Disconnect on start
Hi,
I have just bought an Atomstack A10 Pro. I have got it up and running but i am struggling to run it with full power. I can only set the power to 30%. Everytime i set it higher, the laser moves to position, turns on and within 1 second turns off as if its rebooted. If i lower it to 30% again it works absolutely fine.
What am i doing wrong please?
Congratulations and welcome to the forum.
Perhaps the power supply is faulty, try with another power supply maybe with more a more Amps.
Hi,
You were absolutely right!!! I bought this unit from a guy locally. He never really worked out how to use it so sold it. When we packed it up, we put all the cables etc into the same bag. When i assembled it, it didnt even cross my mind that the plug for the unit is the same size as the plug for the air assist pump! Swapped them over and everything works perfect!!!
Always the simple things!
Cheers!
