Atomstack a24 - xy coordinates in negative space
I have a a24 and installed it, completed few jobs, but then the xy coordinates kept jumping, now to the point they are -97 for x axis and y of 96 even though its in the front left axis and origin for device settings of front left.
The laser is positioned the front left, and I cant even job it up, it tries but bounces back like it hit a limit. What can cause the coordinates to change like this?
Aside from this coordinate issue and not being able to jog up and use the actual bed space, I do hve a homing issue alarm 9 as well, not sure if issues are related but I double checked the connections for the switches but get this code:
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
[MSG:alarmCodeCodeIntHandle:9
ok
Grbl C10-0085-V1060 [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Console code below:
$0=1
$1=25
$2=0
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=300.000
$25=3000.000
$26=250.000
$27=3.000
$30=1000.000
$31=50.000
$32=1
$100=100.000
$101=100.000
$102=1600.000
$103=100.000
$104=100.000
$105=100.000
$110=50000.000
$111=20000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=4000.000
$121=1000.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=365.000
$131=305.000
$132=40.000
$133=300.000
$134=300.000
$135=300.000
ok
Maybe you have a work coordinate offset.
Disable Auto-home at startup.
Connect to laser then on Lightburn console window write $RST=# and press enter.
Click the House in the move window.
Test again and report back.
Why is $31=50?
Thanks, will try that.
Regarding the $31 value, that’s a value I have not changed, I’m not to familiar with each of the lines or values so I have not attempted to modify any of the values.
I will report back later this afternoon on my results.
Okay, I believe that worked.
Regardng $31 - what value should that be?
Im so confused right now. Home button always triggered alarm 9, but tht stopped all sudden, first time ever.
$31 should be 0.
https://github-wiki-see.page/m/gnea/grbl/wiki/Grbl-v1.1-Configuration
