Atomstack A40 Pro V2 - Not moved once
Hello everyone,
I am new in this exciting field and I installed my new engraver - AtomStack A40 Pro V2.
Unfortunately, it has not worked even once and I am puzzled, what I did wrong. Did I make any mistakes while building it up?
The laser has not even moved once yet.
I receive the following error message:
Starting stream
“[MSG: Program End]
Stream completed in 0:00
error 5
Homing cycle is not enabled in your Grbl settings”
I will also share some screenshots and hopefully some of you could provide solutions to me. There is a lot to learn for me!
Thank you!
Spectar
Update: Now I receive the following message and the laser is not working:
Grbl C10-0132-V1002 [‘$’ for help]
[MSG:Check limits]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
What is the issue?
Please help!
Spectar
Power off your laser.
Important: Setup your laser as plain GRBL.
Disable Auto-Home at startup then click OK.
Power ON the laser and verifies it is connected to Lightburn…
Type $$ in LightBurn Console then press Enter
Copy paste here all the output in a reply.
Check if your $22=1 if not type $22=1 in Console and press the enter key.
https://github-wiki-see.page/m/gnea/grbl/wiki/Grbl-v1.1-Configuration
