Hola!! Acabo de aterrizar en el mundo de los grabadores/cortadores láser, me han regalado una Atomstack A5 20w y no consigo que LightBurn la detecte. He instalado unos controladores (ch340) que me dijeron que se necesitaban para el programa, pero ni por esas. Me estoy volviendo loca porque no se ni por dónde me da el aire… Una ayudita??
Hello!! I just landed in the world of laser engravers/cutters, I have been given an Atomstack A5 20w and I can’t get LightBurn to detect it. I have installed some drivers (ch340) that they told me were needed for the program, but not for those. I’m going crazy because I don’t even know where I get the air… A little help??
With the correct drivers installed, open the Laser window and select a different COM port. Press the middle button at the bottom of the Laser window to see your other options.
Open the Console window. You will see a message from Atomstack when your engraver connects.
If after 5 seconds or so, the Atomstack isn’t connected select a different COM port.
Air… for air assist? often comes from a small air compressor - sold separately or added by hobbyists like yourself.
Buenos días @JohnJohn, gracias por la respuesta. Lo intentaré
En cuanto a lo del aire, es una expresión hecha, quiere decir que estoy muy perdida en este tema. Nunca he visto una máquina de estas ni de lejos y no se ni como empezar. Voy a ciegas con los drivers, los programas…
Gracias por la ayuda
Good morning @JohnJohn, thanks for the reply. I’ll try
As for the air, it is a made expression, it means that I am very lost on this subject. I’ve never seen a machine like this, not even remotely, and I don’t even know how to start. I go blind with the drivers, the programs…
Thanks for the help
In the Console window you will see that you are connected when a similar message appears. If you do not see the welcoming message, select a different communication port - indicated by the arrow in the Laser window. After selecting a different COM port, wait a few seconds and watch the Console window. The welcome message will appear when you connect.
