Atomstack A5 Pro 40W Dimension
I have an Atomstack A5 Pro 40W engraver on order. Meanwhile i would like to build an enclosure in advance of it’s arrival. Can someone please measure the height from the bottom of the unit to the top of the X-axis aluminum extrusion. Also the outside width of the X axis including the stepper motor.
Much Appreciated
Just got mine set up, so did a few quick measurements, sizing up to the next full inch.
Length (y-axis): 24"
Width (x-axis): 23"
Height: roughly 12"
Hope it helps!
I realize this is a late addition, but I’ll add it for future readers:
I would add about 7 inches to the height if you ever plan on using the rotary adapter. The adapter has 4 inch legs to raise up the frame, but I made 6 inch legs as it wasn’t tall enough to fit larger items on the rollers.
