Dear all, I have searched all the forums available on the internet, but my Atomstack, despite what I believe to be correct settings, keeps hitting the edges, which it shows in a very alarming way by grinding. For a few months, I have been trying to set it so that it fits within the given size of 400 by 410 Y and X, but despite changes and many attempts, my laser still does not work as it should. I also know that I do not have pins that stop the laser at the edge. I am sharing the current configuration script and hope that someone can finally help me so that I can enjoy my hobby.
I’ve tried a few solutions which, in my opinion, should work, but I’ll attach a screenshot and a photo. The laser in the X position doesn’t correspond to the point on the program. I also changed the device to GRBL M3 1.1, but that didn’t change anything either
It’s exactly as in the instructions, I really feel stupid because I usually solve such problems myself, but this time it’s beyond me. I used the command you gave me, there is some change but not an improvement because the laser keeps hitting the barriers
You are 100% correct.
I am used to all machines having the motherboard front, not the back.
So all you would need to do is the $RST=* in console and your steps per mm should be resolved.
The machine does not have limit switches correct? So homing should also be disabled.
(Edit > Device settings - make sure homing on connect is not ticked on)
So, the laser is in the zero position and starts cutting your example. Tomorrow, I will try to cut a larger piece and will let you know if it works, but it looks like it will.
Also, turn off hard limits ($21=0) and turn on soft limits ($20=1).
You have no limit switches, so it can hit the rails expecting one. Soft limits uses software to determine how far the head can move, based on your $130 and $131 settings. These settings should be a little less than the physical travel capability of the machine. These slight reductions will allow for a stopping distance during fast moves.
First of all, I would like to thank everyone for their help. Now, briefly, if you are a user of the Atomstack A5 Pro Plus and intend to use Lightburn, set the laser size to 10 mm less. Also, change the stoppers to hard or soft, as we do not have automatic switches. Always start your work by setting the laser in the bottom left corner and then turn it on – this is our starting position.
