Hello everyone,
I have an AtomStack A5 Pro laser engraver and I am having a startup problem.
The machine powers on, but it does not boot correctly. The controller seems to start partially, but the laser is not operating normally. I am trying to determine whether this is a firmware issue or a hardware problem.
I have already checked the power supply, cables, and connections. I also tried restarting the machine multiple times.
Below is the information returned by the controller/GRBL:
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DOUT, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5856
entry 0x400806a8
ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
entry 0x400806a8
entry 0x400806a8
Could someone help me identify the controller, firmware version, and recommend the correct firmware if a reinstallation is necessary?
Thank you very much for your help.
Does anyone have the firmware for this machine? It is an AtomStack A5 Pro with a Laser32 A5 V1.0 controller board. I would like to update or reinstall the firmware because the machine is not booting correctly. Any help or firmware files would be greatly appreciated.
