Atomstack A70 MAX
Anyone have an Atomstack A70 Max that can export machine settings and send me a copy
Just send $RST=* in the console and all settings will be reverted to factory defaults.
Already did that. Having some issue with new machine .
Machine says X Max is 850, Y Max is 800
But when i set lightburn to that in device machine work area is not correct
If i set lightburn device to X Max 800 and Y Max 850 work area is correct
Even then if i move Y axis greater than 800 it crashes into rear rail
Also having issues with Z axis, does not home when i home machine. If i send $HZ command sometimes Z will home and sometime i get an error 8 like it doesn’t see Z limit but Z limit seems to work ok manually. I can move Z up and down with Jog Keys. This seems to be a mechanical issue with drive motor and screw that drives Z axis. Sometimes it rattles and wont move when i jog or try and home
When i turn on machine Red Cross hairs is on. When i Frame Cross Hair turns off and laser turns on.
This is the second machine they sent me. First one had other issues. This one has a different set of issues.
Getting very frustrated with the whole thing
If you set Ymax to 850 while the machine says it is 800, yeah, it is going to crash into the rail. That $131 parameter is the physical limit of your travel (and even be a little less), and Lightburn should match. The machine is in control, not Lightburn.
What do you mean “work area is not correct”?
Error 8 has nothing to do with the Zaxis. Was it an Alarm 8? That indicates your pull-off value is too small. Increase the $27 by a mm or two.
This is likely controlled by a GRBL parameter, which you would have to get from the manufacturer.
Slow down and take it one fix at a time.
