Atomstack Ace A20pro V2
I got the new Atomstack Ace A20pro V2
Installed and everything is ok
The only thing is that while having the data read from the machine in LighBurn it doesn’t match the working time from the preview to the actual time.
Solutions?
Have you read the data from controller?
Edit > device settings > Advanced tab
Read from controller
Also the estimated time is aproximate, and if you are doing engravings - specially images in say Grayscale, the machine speed “advertized” vs the real speed are not the same so
rule of thumb.
Vectors = Estimated should be near exact
Images = Double the time that should do it roughly
Yes, I had the controller read, with the A20 Pro I had before the times coincided with this new one but not
