Atomstack camere did not kept configuration
hello,
I bought Atomstack camere and calibrate it and everything. Im runing Apple air 2011.Another day I wanted to use it, but it did not found proper position.It was even not close to position, differenc like 10cm. Any ideas what could help?
thanks
Tomas
If your camera overlay became misaligned between uses, it means that the position of your camera relative to your workspace has changed from when you did your initial alignment. How are you mounting your camera? Make sure the camera is securely mounted with no wiggle. If it’s on a lid, make sure the lid is returning to the exact position it was in when you did your alignment, and that there is no play in the hinges. Make sure your engraver itself hasn’t moved at all - engraving movement can sometimes jostle a laser’s position.
If you switch to a thicker or thinner material, that can cause a misalignment (the height between camera and workspace will have effectively changed).
You’ll need to address these issues, and then re-run your alignment.
Here are some additional resources on the camera alignment process. Please review them to make sure you complete alignment properly.
Finally, if you are still off a bit, you can use these numbers in the Camera Control window to fine tune the placement and scale:
The ‘Shift’ values move the background image around, and the ‘Width’ & ‘Height’ values adjust the size. When you have it aligned, click ‘Save’ so the values persist.
