Atomstack P9 M50
Please, I would like to know $20 $21 $22 $23 $101 configurazion numbers for Atomstack P9 M50
The device will report all these settings when requested.
From the Console window in LightBurn, please type the following:
Then press Enter.
You’re welcome to Select that text from the Console window, copy it and paste it into a reply here.
If you are concerned that you have unusual settings and you’d like to compare them to what the factory settings are, this is a controller that will retain factory settings when you reset the changes.
$RST=$
should reset any settings between $1 and $165 to factory values.
After this, you can reissue the $$ request and look for changes.
This may be of interest.
