Anyone get atomstack rotary to work with a kentok in light burn. When you setup rotary function nothing gets controlled.
Which Kentoktool laser engraver do you have?
Can you plug in the rotary where you unplug an axis drive motor?
Are you already connected to LightBurn?
It’s a model LE400 yes you can plug it into the unit. I have done that. When you go to the rotary set up In Light burn it will not control it at all.
If they’re visible/ legible, would you mind posting the ID numbers from the stepper motors. If it hasn’t roared to life at this point there might be something unusual going on.
Any hum or attempts at motion from the rotary?
What voltage is written on the power supply (brick) that came with the LE400?
