Help! Atomstack S20 Extension Kit + Atomstack AC1 Camera.
I has Atomstack S20 Pro 130W with working area of 400/400 mm .
Now I use Extension Kit from Atomstack and now my working area is 400/850 mm.
I use Atomstack AC1 camera but now with extension Kit I have a problem . The camera can’t see my working bed. It see again only 400/400 mm of my bed and I can’t align material corectly .
My question is : Is there a way to use Atomstack AC1 camera with Atomstack Extension Kit ?
Usually, no. You can use the camera, but only with 400x400 and if you want to use the big workspace, don’t use the camera.
To ease operation, add your laser twice, once with the small workspace and once with the large workspace. Then you can switch fast in between. Do the camera calibration on the small workspace device. Mount the camera that it sees the homing location. Som tips: Using a camera with a diode laser - Diode Laser Wiki
