Atomstack S20 PRO Y-axis Tip
Hi Everybody! (in my Dr. Nick voice)
If any of you are having issues with your Atomstack S20 Pro not moving at all or not moving smoothly on the y-axis, you may want to check the wheels that allow it to slide on the rail. I’d been having no problem with getting the x-axis to respond to LB, however, when trying to get it to home, it would simply vibrate after the x-axis travel was completed, thus never allowing it to successfully ‘home’. After making sure that the belt tension wasn’t too high and the wiring for both stepper motors were good (even switched them to be sure), I noticed that moving the x-axis motor assembly on the rail by hand was much easier than the y-axis…the y-axis motor assembly was not only harder to move, it also felt a bit ‘clunky’. I loosened the top wheels up just a bit and that solved the problem. Apparently they were tightened just a bit too much from the factory, and since I hadn’t seen anyone mention this on any forums or searches as a possible cause for the original problem, I wanted to share it with you all in the hopes that it saves someone else the frustration…hope this helps, thanks! :nerd_face:
Thank you very much! I had the similar problem with my Atomstack s20 Pro. I loose 2 days of searching in the YouTube for solutions but without success. Now I solved the problem thanks to your advice.
Please help. I’ve had the laser for 1 week and have the error.
I accidentally changed something in the machine settings and don’t remember what :-(.
Can I set the machine setting to factory default?
If yes how?
How can I solve the problem?
Please help.
ALERT:9
Homing failed. Limit switch within search distance could not be found. Defined as 1.5 * max_travel in search and 5 * pulloff in search phases.
OK
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
OK
[MSG:Local access point Engraver_63500 started, 192.168.4.1]
[MSG:HTTP Started]
[MSG:TELNET Started 8080]
OK
[VER:1.1h.2022070601:]
[OPT:VZ,15,128]
Target buffer size found
OK
$0=10
$1=25
$2=0
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=3
$24=300,000
$25=3000,000
$26=250,000
$27=1,000
$30=1000,000
$31=0,000
$32=1
$37=1
$40=2
$100=80,000
$101=80,000
$102=80,000
$103=100,000
$104=100,000
$105=100,000
$110=6000,000
$111=6000,000
$112=6000,000
$113=1000,000
$114=1000,000
$115=1000,000
$120=1000,000
$121=1000,000
$122=1000,000
$123=200,000
$124=200,000
$125=200,000
$130=400,000
$131=400,000
$132=200,000
$133=300,000
$134=300,000
$135=300,000
OK
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
OK
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:P|Ov:100,100,100>
OK
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:P>
OK
Stream is started
[MSG:Program End]
Stream completed in 0:00
Stream is started
[MSG:Program End]
Stream is started
[MSG:Program End]
Stream completed in 0:04
Stream is started
[MSG:Program End]
ALERT:9
OK
OK
Thank you. Very userful. :+1:
Hi! Please follow the steps below:
  1. Set the current position on the software;
  2. check the limit switch for damage;
  3. take a video of your operation to see.
I’m glad you found it useful!!!
