Atomstack x20 doesnt cut oder engrave with Lightburn
hi there,
I hope this is rihght chanel.
I have a Atomstack x20 pro and udes LaserGRBL. Now i changed to LIGHTBURN.
Use the Laser with SD card. LaserGRBL worked good.
But now the problem with Lightburn.
The laser traces the paths, but does not engrave or cut.
I have tried engraving and cutting spar.
3000mm/sec
20% power engraving
600mm/sec
50% cutting.
The laser lights up when it moves but does not engrave or cut.
Can you help me?
3000 mm/min seems more appropriate for a diode laser.
Diode lasers generally use mm/minute, rather than mm/second.
If LightBurn is currently set to use mm/sec, try switching to mm/min with the same numeric value.
Hey ednisley,
Yes! Thank you so much.
That is of course logical. Stupid mistake on my part
I have a stack of t-shirts with that legend. :grin:
