Atomstack X20 Pro cutting/engraving text fails miserably
Hello there!
I recently bought a used X20 Pro. Everything works just fine with LaserGRBL, but then I wanted to try Lightburn for easier moving and arranging individual parts and optimizing paths and because it’s the undisputed overall superior software.
Problem: The result looks like this:
That should read ‘Test’, engraved as lines on a 3mm MDF board.
Not only is the text illegible, but to top it all off I used 50% power at 1500mm/min for this. Setting the laser to F=1500 and S=200 in LaserGRBL (same speed, 20% power) usually did the trick on the same material, this time said settings didn’t even leave anything visible.
What went wrong here?!
$0=10
$1=25
$2=0
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=3
$24=300.000
$25=3000.000
$26=250.000
$27=1.000
$30=1000.000
$31=0.000
$32=1
$37=1
$40=2
$100=80.000
$101=80.000
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
This is indicative of a license validation issue. Make sure you only use copies of LightBurn downloaded directly from the official site at lighburnsoftware.com
Oh, well that’s quite an easy solution now. Should’ve tried the trial version fist before sailing straight into ye olde familiar waters :pirate_flag:
Thanks for the quick answer, installing the official download really did the trick!
