Atomstack x20 Pro issues with setting up in sofware
hi there friends
i have an issue when setting up my X20 pro laser
the software doesn’t recognize the laser as x20 pro and just as an GRBL laser with a 10mm x 10mm work area
additionally i cant set up a min power setting for the laser just the max, so no mix\max setting
any help would be appreciated
attached a photo of laser detection
In one of the next windows you should be able to set the work area size manually, that did just fine for me.
It won’t. GRBL is the controller type.
Is your Device type “GRBL” with nothing else in the name? It must be GRBL only. That said, not every situation allows a minimum power setting. On the diode lasers,
@tobydebeer is right. This also is not a one time option. It can be changed at any time. I found it is much easier to simply create a Device manually. It is almost a no-brainer.
Congratulations on your machine and welcome to the Lightburn forum!
