Atomstack y-axis
Hi everyone,
I recently got an atmostack a5 laser engraver. When setting up I can only seem to get the X-axis to move, I have switched the input driver (not sure on the terminology) to the motors to test that the y-axis motor is working and this does work but then the X-axis won’t move.
I am using the latest version of lightburn and I am on a Mac. I can’t seem to diagnose the problem myself and I am unsure if this is a lightburn issue or my atomstack being the issue?
Thanks in advance
First of all in which way have you done that test? Only connecting the X cable to Y?
Yes I tried connecting the X to the y to check if the motor worked which it does.
Ok now you have to try the Y cable, connect X with Y cable and check if also cable works
So I have tried that now and the y cable doesn’t move the X-axis motor
So is a cable fault, you have to change cable
I was afraid of that, I will have to get in touch with the company for the replacement thanks for your help
