Fehlermeldung:Schnittdatei auserhalb der Arbeitsfläche ,was kann man da machen
Error message: cutting file outside of the working area, what can you do there
Make sure you have no objects outside the workspace. You can check by using ctrl-shift-a. This will select all the objects that are considered for your job.
A few workarounds if you want to leave objects outside the workspace:
Danke für die Antwort.Ich werde das ausprobieren.Ich bin noch neu,ich habe den Laser erst ein paar Tage
Thanks for the reply. I’ll try that. I’m new, I’ve only had the laser for a few days
