After setting up my Atomstack A70 pro I am having problems with work space. After using auto focusing button on my lightburn dashboard, I try to start my job but the laser module goes way off from my design I was just framing over. I am set to absolute coords and home the machine at start up. I am so frustrated because all my other machines have no issues.
There might be something outside your design. Use CTRL-A to see if there are any remnants out there.
Use the Cut Selected Graphics in the Laser window. I do not use, but some say to turn on Use Selection Origin also..
Is this a macro button in the console window? If so, show the contents of it. I suspect the command to reset not only the z position but also the x and y coordinates.
The only way to use Autofocus with Lightburn and the A70 Pro is to set up a Macro in the console.
This is the command that will do that. [ESP500]
Running the macro should have no effect on framing a job
When you Autofocus it will focus to the “Engrave” position above the workpiece .
When Homing the A70 Pro it will automatically home the X Y and Z axis
I agree with the above that you have something else going on.
Are you framing with the Blue diode laser or the Red X
Here’s some instructions i wrote on how to use autofocus with the A70 Pro or A70 Max
Download this document and then change the extension from .txt to .pdf
How to Use Autofocus in Atomstack A70 Pro and A70 Max.txt (78.5 KB)
